2007 dodge 3500, 8x6.5 bolt pattern still?
y5mgisi
1 ton status
Portland Oregon
A buddy wants to know. He just got a nice dodge crew cab 3500 4x4 and wants to put his other fancy wheels off his chevy on there. Should work right?
same bolt patteren but make sure the inner hole is opened up to at least 4.7" or it won't fit over the hubs.
thats why guys that get H2 hummer rims on their dodges have to machine the centers bigger to fit over the hubs/ Chevy hubs = smaller than dodge D80/AAM 11.5" hubs.
The 11.5 AAM GM and Dodge Version use the same hubs they are also the same as the 14 bolt hubs, the reason H2 rims are different is becasue they are on a semi float axle
oh good point on the semi floater, didn't think about that.
though my 14bolt in my '97 dually does have a smaller hub diameter than any of my D80s. I can measure for exact #'s but the 8-10 lug adapters are hub pilot fit on the D80 and have to be stud piloted its so loose on the 14bolt.
I had a guy with a megacab dodge come by the house a while back to buy the wheels/tires that were on my k3500 and it's a good thing we test fit one because even though they were the same bolt pattern the brakes on the dodge were so big they wouldn't fit over the calipers...
Since you said "fancy wheels" I'm sure they're large diameter but that's something to keep in mind too.
