Hi guys,
I know there some forklift repair guys here so I hope you see this soon or someone who knows you tags you.
I have seen some of your posts but can't remember where or who.
I have friend who has this forklift and it suddenly stopped starting.
It will crank but no sign of starting.
I checked for spark and nothing.
I tried to trace all the electrical system and so far I located the crank sensor plug, 3 wire hall effects system.
I am not able to see anything in the testing of the sensor, on power source I see 2.5 volts with ignition on.
I located the coil but not sure how to test it, I tried testing the wires coming to it, 2 wires get 0.6 volts.
No change if I am cranking.
Checked all fuses and relays, all good.
Any help is appreciated
