fidelity101
Okay great. I'm sure you've probably been through this but I ordered a book from Larry Hofer on 8.1 build stuff and it talks about if you are using that kit with 8.1 that he cut a piece of moon shaped aluminum to fill the groove in the bottom of the cover and JB welded in and them ground it smooth so there was a smooth surface for o- rings style pan gasket to seal against otherwise it would leak. I don't know if that helps you or not.
I have not read the book - hopefully the new cover does not have these old issues. its a different design - I had spoke to him about this swap and we went back and forth on some ideas but ultimately he wen't a different route - I had asked him about how he handled the 58x conversion and he had mentioned its in the book...
I double checked the balancer and I had taken off 3.-4mm last time, I just dropped off a new balancer to be machined 2.5mm and go from there, it seemed a bit much and was given some bad belt angle possibly related to why it wants to toss the belt at any throttle over a puddle.
next up is exhaust leaks and hydroboost leaks and a another re-calibration. Some general spring time maintenance
