2012 Honda Odyssey problem
TJ1978
I have MANY questions
East Valley, Arizona
So today the "check engine light" came on with an "emissions" and "vsa" code
Or vehicle stability assistance.
I read could be catalytic converter going bad, bad O2, or.... a myriad of other things.
The vehicle is due for an emission test this months as registration is due.
it brakes and corners fine but normal driving is odd.
2012 Honda Odyssey touring with 179,000 miles.
What causes this?
What is the solution?
I've read when both come on simultaneously that the engine is burning oil and spark plugs need replacing. But, I guess I can pull a plug and check.
Or if it's fine to drive with VSA on I can just get it to the mechanic who works on all my newer vehicles when I can't.
And yes, I already checked the gas cap and it's on tight.
been reading it is most likely cylinder ring issue.
I don't know exactly. Wife brought it home but I may need to go to autozone or rent their scan tool. I've also read this issue may not be located with the autozone type scan tool
you can drive with the stability assist like on. It will default, to no traction control. Smokey burn out time :saweet: . Kidding about burn outs. Abs may effected too, but brakes will work. So with the vsa light on you Pilot is now a Japanese K5. the check eng light might have been commanded on be cause the VSA has an issue.
another car ?? the short bed needs paint. No I'm being silly. If the car works for you and the repair is reasonable, and passes emissions. Keep it. Now if you have a line on nice used car that isn't over priced that you like then sure sell it. But people want stupid money for used cars today
I wish, I could trade this in to finance the c10 paint job....hmm.
My wife could drive the rav4 then I can daily the beast k5 until the c10 is done..
Hahahahahah
I'm going to see what codes I get and go from there. Kelley blue estimates the cash value for the van at around $8,000
Hahahahahah
The Beast will look so good in a Trader Joe's parking lot, hehe some offences may be triggered
I plugged in the scan tool but nothing happens I only get this screen then none of the buttons work and the only screen I get is this
I push read and it just beeps nothing happens
No codes come up nothing happens. I push every butting and it's just beeps is it broken?
I think i got it. Not the code I wanted.
Burning oil according to other Honda sites
