2018 last minute thrash.
Yes it sucks , came on all of a sudden Wednesday after noon, after going to the doctor and finally figured out what was going on ,my wife said your not dying and you’ve worked to hard u to now so go finithe blazer and go.
Do work sound like lots of good news on your end.
Everyone running Golden Spike:
Keep in mind we are running 2 separate sorties:
@4door99 is leading the first group leaving at 8 am
@kgblazerfive is leading the second group leaving at 9 am
A military term usually reserved for air missions...
For example, when a fighter takes off from a carrier, completes the mission, then lands, that was a sortie.
Electrical Issue - diagnosed and repaired
Death Wobble - diagnosed and repaired
Need to do
Oil and filter change - Done
New spark plugs - Done
Check winch operation (probably needed for Pritchett) - Done
Heat insulate cab floor - not going to get done before the trip:frown1:
Wash mud and dust from the last several trips this summer - on the list for Monday
Take care of mother-in-law's home repair list - that was the first thing that got done!
Love being able to just pressure wash it inside and out, not real happy with front drive shaft angle thought.next up is mounting winch.
Curious about the drive shaft
It does not look like you have much up travel before the shaft bottoms out. That will likely punch the Tcase off the transmission if you stuff it
That is my concern along with if I flex to far it will probably bind.
Just ordered a full set of yukon 4340 axle shafts, supposed to be here Wednesday. Gotta get everything else done before then. Mount tool/parts box, fire extinguisher, CB, lights, change oil, weld in new exhaust...taking it to the wire, lol.
I guess that I will find out if you are taking it closer to the wire than me.... we will have to wait and see!
:rotfl:
Got a coolant leak on the tow rig that I cant find. I'm pulling the downpipe tomorrow so I can get to a coolant blockoff plate that may be the issue. If it's not leaking, I don't know what else it could be. Leak is too big to chance towing to Moab.
I'm not happy
