A lot rides on how much my job keeps me busy.
OK....Ready?
Pull motor and trans back out so I can install rebuilt torque converter and Lokar shifter. (Shifter should be here by Friday) Motor and trans was installed to get new lengths for the driveshafts.
Re-install motor, transmission and transfer case.
Send in both driveshafts to have front lengthened and rear shortened.
Install headers. (Sanderson headers will be here next Monday)
Build exhaust.
Install gas tank
Install all front brackets and wiring.
Install Water pump, Radiator and hoses, alternator, A/C, power steering pump and hoses.
Add antifreeze and rest of fluids.
Install driveshafts.
Install Transmission lines, Fuel lines.
Install one battery (Temporary)
Install seats and seat belts.
Hook up gauges.
Add oil and transmission fluid.
Add small amount of fuel.
Fire this beast up.
If it doesn't run good, get on here and beg for help.
Get help.
If runs good, drive in town for approximately 300 miles for new motor break-in.
Change oil and filter.
Bleed hydroboost brakes.
Install complete front end, including wheel wells, fenders, grill, hood, second battery.
Install rear tailgate
Install both front and rear bumpers.
Install winch.
Connect all wiring for lights.
Install stash box.
Put hard-top on.
Haul our butts to Moab.
If all else fails, then we go to plan B...............Rent a Jeep and see you at MOAB RIM RV PARK on Wednesday evening.
Either way, we will be spending our vacation in Moab, Utah.
