203/205 Doubler Crossmember pictures
If I understand the measurement you want...the top of the mount for the doubler adaptor is 1/2" below the bottom of the frame rail.
That is the one... Thanks. I do need the one for the front, but I will have to get that from another vehicle with a 465
Thanks again.
Mike, I have a few stock style crossmembers, including 1-ton that has little drop. I was going to use those till i built mine to raise my drivetrain higher
Rene, how long was the rear d-shaft with this setup on your Blazer?
The rear is 32" long center of the cup to center of the cup. It's a 1410/1410 shaft cuz I thought I could get away with it...
I did buy a companion flange and 32 degree CV head for it but never got it altered. I'll do that when I get it re-tubed for the Crew cab.
Rene
