damn, there is all kinds of misinformation in this thread;
203 is chain driven and has a 2:1 low range, all are fulltime unless converted to part time with a kit; ergo the full time hubs. 203's were last used from the factory in 79. also, in the 203, there is a lock position in either low or high range where you can lock in the differential inside the case so it is not open all the time as previously stated.
in 1980 all trucks and blazers got the 205, albeit with a slip yoke rear driveshaft. it was also available in later HD models with a slip yoke. the 205 has a 1.96:1 reduction. it was available in earlier years with a fixed yoke behind the manual transmission. it is a gear to gear case. also, i have had 4 73 model trucks and blazers that all had the 205 behind the turbo 350.
the 208 was used in 81 and later trucks until the 241 came along in the 88 year model, which used both. the 208 is a chain driven case with a 2.61:1 reduction. all are slip yoke but can be converted with a dodge case. the 241 is also chain driven and has a 2.72:1 reduction. you can buy a fixed yoke conversion from JB conversions for the 241.
