Found 205 Denver/NoCo
Bent77
I am CK5
Nunya
Any input spline
Need a parts 205, PM me
Everything on the front output side, forks, rear case plate. Fine spline front output would be ideal
Ive got synchro front parts left if you decide to do something stupid and use those.
Thanks, but I'd like to stick with the non synchro stuff
I am out . Checked and only have early 10 spline front shafts left .
I do have the rest if you dont find any .
Sorry. Just now saw this. Hold tight and I’ll see if I can get everything else
I might have one of the alum plates. Came across it cleaning up. I can mail it to you for free. I just need to find it again... LOL
Dug more and found my LAST 30 spline front . Few spots from water sitting there years ago .
I have all good used parts ready to assemble with your 2 gears .
Shaft 30 spline & nut .
Frt bearing snap ring .
Rear bearings and spacer washer and tiny pin and thrust washer and snap ring .
Rear cover with good used FULL needle cage bearing .
Great fork and coupler .
This is the piece I have. Let me know if you want me to ship it to you.
Parts list . . . ?
Last pic is 4 cases on corner of bench. . .
I need to bore out ALL these cases to big bearing input size. . . .
And yes there is a ford divorced 205 there AND divorced range box ford 203 .
Twin stick not mine to sell .
Frt shaft spacer i had custom made cause superlift units were ALL bad . Hub center hole was opened up to much . So this one DOES fit correctly . I can be persuaded to possible sell it yes .
Dodge are i have blasted and painted and re-tappered for top load gm stuff over dodge lower load . Possible sale yes .
Pm me and we go from there .
