Found 205 Denver/NoCo
Twin stick not mine to sell .
Frt shaft spacer i had custom made cause superlift units were ALL bad . Hub center hole was opened up to much . So this one DOES fit correctly . I can be persuaded to possible sell it yes .
Dodge are i have blasted and painted and re-tappered for top load gm stuff over dodge lower load . Possible sale yes .
Pm me and we go from there .
Ok had the chance to inspect the case. Idler and input side are fine
for the front output side:
Rear cover + roller bearing
Main gear rollers (64 I think you said)
Shift collar
Shift fork
Snap ring for the front bearing
