205 fluid
TheGeneral
NC, USA
Doing a doubler swap and wondering about fluid type to use. Detron ATF or 89-90 gear oil? Thanks for any info.
If you ain't hurt, you ain't playin' hard enough.
The General
80-90 weight all the way!
I'm not picking my nose...I'm just pointing at my brain!!
<a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
atf was speced as the fluid in the 80s
lighter fluid = better fuel economy
I use the 80 90 but a synthetic would be ideal for those that dont change the fluid regularly
i buy gear oil 20l at a time and have the pump, when I used to play every weekend I had to drain the water fairly frequently.
I've always used 80-90w. I think got that from the Haynes manual.
<font color=red>Sure your Durango can go any place I can go, (if I hook a strap to it).</font color=red>
That is why I was asking. That it spec. do different fluids based on years? I'm going with 80-90 gear oil.
The General
mazola
Like to go sloppin' 'round in da mud in a rapid fashion....=)
<a target="_blank" href=http://coloradok5.com/gallery/albun31?&page=1>See my pics here</a>
