205 front yoke and gaskets
bigbadchev84
Hermiston, Oregon
I just picked up a 465/205. It is out of a 1985 1ton and it was missing the front yoke. I have a parts 208 and was wondering if these are the same spline count? If not anyone know where i can find one?
Also I am needing some 205 gaskets, I got 3 of them total that I need to get sealed up and need the part numbers if possible.
#1 465 to adaptor
#2 465 adaptor to transfercase
#3 th350 adaptor to transfercase-is this the same as the 465?
#4 seal inside the th350/205 adaptor to prevent fluid between the 2. Are there 2 gaskets in there? It is from a 1972 blazer.
A 1985 NP205 would have a 30 spline front output and ALL 208/241's are 32 spline so unless you swap a Ford front output shaft into the 205 you can't use the 208 Flange.
Anyone want to take a stab at the gaskets? I called the dealership and they said they have no way to look up the part numbers? Tranny shop wants to sell me a whole seal kit.
