205/ Input shaft/gear
Don
Spokane Washington
Doe's anyone have an input gear for a 205? 32 spline for a TH400?? /forums/images/graemlins/eek.gif How much is it gonna set Me back? /forums/images/graemlins/eek.gif
I purchased a brand new one for just over a hundred dollars, if that gives you any idea on what a used one is worth.
Are you converting from a different spline? If so the case will need to be bored for the larger bearing. You can buy the conversion kit from ORD for $200.00. You get a 32 spline input gear, front bearing, and a gasket/seal kit.
I've read that and was just wondering. I suppose if You add in the machine shop labor, to bore the case to accept the larger bearing, it would just be easier/cheaper to find a 400 case for the 205? /forums/images/graemlins/eek.gif
You can also buy a completely rebuilt 205 from ORD that already has the 32 spline input and whatever spline front output you want for 850.00 plus shipping.
