205 Questions?
84 K5 4x4
Jasper Ga
Is a 10 spline front output shaft the same size as a 30 spline? Or in other words I'm swapping from 10 spline to 30 spline and can i use the same bearing and gears or do i have to change anything?
So swap your bearing onto the donor shaft and install in your case.
