229 powered elcamino timing issues
supersize75k5
OrganDonorRacing.com
gilbert az
trying to get a 1981 elcamino on its feet, three shops have thrown money at the problem.
seems the 4 years of computersontrolled carbs ment a odd dist set up.
car has had new parts thrown at it, now I want to ditch the comp controlled carb.
thoughts or info on years, i did find out the buick 3.8 parts will not work as people have told me it would:doah:
The Buick is a totally different motor. I had a 229 in an 84 S-10(not OE). The carb was a staged 2 barrel, w/o comp feedback. I believe the bore/stroke is the same as a 305. Just drop a small block in it, and be done.:D
Its a Chevy V-8 sans two cylinders . You can run a six cylinder regular HEI from earlier models from the late 70's , and a Quadrajet or dualjet on it .
Summit and Jegs can even ship you out a bling distributor if you prefer pricey and bulletproof .
