241 input and planetary set
1-tonmudder
In a junkyard somewhere
27 spline input and 6 roller planetary set from a Chevy NP241 case.Looks good and spins free.$120 shipped.
Would you be willing to get the outer "ring" gear out of the case and make it part of the deal?
Ring Gear Removal....
The cleanest "garage floor" method we use for remove involves a sawzall with a 12" heavy duty blade. We basically part the case on both sides of the gear and relax the fit with a chisel. Other wise clamp the sucker in a large bandsaw if there is access to one.:D
