I remember seeing a post somewhere, can't remember if it was here or on Pirate, but using a 208/241 with the front output cut off, using just the low range portion. I've seen it using as a doubler, but I want to keep the rear output, then with a small drive shaft going in to a div 205.
I never messed with a 208/241 before, would it be just cut the housing, take the chain and junk off?? Make a plate to seal up the hole???
