royjones
Trucker upper
somewhere close to ya
Hey guys Is there a cheap way to clean the inside of a diesel radiator? I didn't want to take it out . I thought you guys might have some ideas
If you are disconnecting it, its just 2 more brackets to remove it.....
Most radiator shops will boil it out to clean it for you. Other than that, there are probably some solutions at the parts store, but i tend to just flush it and move on.
dishwasher soap or TSP.....both are non foaming.....and will dissolve grease and oil...
worth a try.....
muriatic acid.... been doing it for years...
Tell me about this please lol
you can use oxalic too... actually you can combine the 2 too... but we tend to just buy muriatic..... it works better on bronze which we see TONS of...
there aren't any real guidelines to acid strengths vs materials per se, occasionally you'll get a manufacturers recommendations on flushing, but it's usually an experienced "know what the metal of said item" can handle, and how long...
that being said... radiators are pretty dainty... i never run the concentration of acid that i run on lots of boat parts on a rad.... usually i'll add a gal of muriatic to about 2 or 3 gallons of water... NOTE: ALWAY ADD THE ACID TO THE WATER, NOT VICE VERSA! and yes, gloves, goggles and a respirator are advised.... take it someone who knows VERY well what it's like to have the oxygen sucked out of your lungs from the acid fumes... :eek1: not fun...
also.... thats a pretty mild solution.... i'd generally let that sit in the rad for about 15, 20 minutes... if you go to the local hardware store and look at the muriatic gals, the %'s are VERY low today... usually they only have a couple % acid in em anymore... used to get it and it was 15, maybe %20....
flush very well..... sometimes i'll mix a couple tablespoon of baking soda in a couple gals of water and run that thru, as baking soda nuetralizes the acid... then cleanwater flush....
DISCLAIMER....... I'm taking no responsibility for anyone nuking their rad..... use at own risk... borderline failure parts, can fail.....
`Dupont used to make the best radiator flush,a two part system that came in a can with two halves--you would add the cleaner ,a powdery substance,to the water and run for awhile,then you'd put the neutralizer after thouroghly flushing out the cleaner,so it wouldn't keep eating away at the radiator...not sure if they still sell it or not,haven't seen it on store shelves lately..(maybe since aluminum radiators came along they dropped it from their product line?)...it either worked great,or made your borderline radiator into a sprinkler!..
Yup.....that stuff worked well....:waytogo:
we used to just use TSP or dishwasher soap in diesel reefer units when they blew a head gasket and dumped oil in the cooling system.....run it for an hour or so and then flushed it out .....
the DuPont stuff worked really good.....
