COCHEV
Is this doable? I'm not a fan of cranking the T bars. I know 265s fit just fine, but if i could squeeze the next size up, I'd like that better. I've got grandpa 245s on there now...truck is a 97 2500 gmc
My BFgoodrich a/t ko's fit fine and no rubbing. my buddy had the same truck and bought some firestone destination mt's in the same size and they didnt work. he ended up selling them and going smaller. I think your 2500 is a little taller than ours so should be fineRandom thought but 255/85R16's will fit, be as tall if not slightly taller than the 285's, and thanks to the narrower width will be even less likely to rub.
Very common in Load Range E too.
I had them on a '99 suburban 2500, BFG at on '07 2500 hd aluminum rims only had to trim.a little off the front bumper. If I did it again I would go the 255 route. In my opinion the 285 looked a little pinched on the stock width rim.
I know the 00-whatever 16" HD aluminum wheels were 7" wide. I had a set for Big Ugly that I never used.
