Vombrown
Mountain Man
Ok to preface, I need a dually. Well need might be stretching it but you get the drift.
It's a 76 c-30 with a fresh 396/400 turbo. Truck hasn't been driven in about 4 years. I need it to be 4wd as getting up on my mountain is a no-go without it after September in 2wd. I have all the parts for the swap except crossover steering I think. Questions:
I have a GM specific Dana 20 that will bolt to the turbo 400. Wondering if it will take the torque. (Stock rebuild on the 396)
Engine cross member: How much lift will I need to clear the differential if I don't want to swap it out?
I have a Dana 44 8 lug outside and most of the brackets should swap from a parts suburban. It's cheap, I can get it for 700 bucks and the body is decent with a good flatbed. Webber carb on it too which is sort of unusual, I guess.
