Project "RESPAWN" - 1972 K5 Blazer
Cool stuff here!
Looks like for what ever reason my new sending unit is not working properly, crap right out of the box, gotta love it.
Dorman for the win!
Part number 692-056
I will need to switch the pump and sender wires around, probably on the Blazer side. Thinking PO switched the tan wires around at the gauge and power side.
Thank God I tested the sender before putting the tank up and filling with gas.
Another way to test a sender using any GM gas gauge. Used one of my Milwaukee 12v batteries as battery source.
Great video on how to hook up the square body gauge and test the sender.
The Walbro GCA758-2 just came in. The picture from Summit shows a connector for the pump with nothing on the other ends but it does come wirh a connecter that connects to the factory sending unit. Nice so I don't have to wire the other end! :saweet:
As cool as the koozie looks, it's coming off as I guess it can retain heat when not submerged.
Sucks how much junk you have to go through to get something that works correctly.
  • Like
Reactions: CK5
Got a couple of tanks in, decided to go with the Spectra Premium GM15 C tank. Forgot to mention a few things in the video but you get the idea...
Looks like there is some surface rust spots starting in the dorman.
