it barley hangs below the frame, just the t case. need to fab up a new crossmember though. ill prolly splice an olds s crossmember i have with the flat one that came in the truck
hopefully ill have the springs hanging this week. *fingers crossed*
oh the abilities are there, i just dont always use them, or im typing to fast to noticebig94gmc said:Muahahahaha!!! If it's anything like your grammar abilities, you're better off, my friend! LoL!![]()
Good luck, man... Keep us posted on the progress.
anyways heres the springs mounted up still waiting for the correct rear hangers and then ill have to buy some
i inderstand...im getting better but its hard with a 100 amp stick and 3/16" and 1/4" steelsled_dog said:no offense intended, but from what welds I can see, the decision to bolt is a good one![]()
the ones you can see close up are the first ones id did too so there are better ones. but for the record the are badd looking but theres plebty of penetration, im not worried about how well they'll hold. I can tell what a penetrating/ good weld looks like, even if i cant make mine look that good...
thezentree said:So how are you gonna attach those rear shackle hangers, just those three rear bolts? Seems kinda flimsy. It may hold, but you have a welder, so you oughta at least run a bead around the front of it. I'd weld the whole thing. Even though you say you don't like it being permanent, you're converting the whole front suspension and drivetrain of the truck and cutting a hole in the floor of the cab. Are you really gonna convert the truck back to stock?
I mean, even if you decide to change the SAS brackets or even go back, it's still gonna require fabrication, so why not bolt AND weld? Overbuild the thing. Even though it's gonna be trail-only, do you really want to rip your suspension mounts off the frame?
Also, since suspension is so important, I'd grab some extra rods and practice laying some beads on all that old 2wd stuff you got. The extra practice can't hurt.
Looks good otherwise. I'm lookin forward to seeing this thing finished!![]()
