My 89 k5 has a 3/4 axle swap previous owner did out of an mid 80s suburban I believe , question is when ordering a lift kit would I got with the 89 1/2 ton k5 lift kit or a mid 80s suburban 3/4 ton lift kit ... Seems like the 3/4 ton burban lift kits are cheaper than the 1/2 ton k5 kit ... For example 4 inch lift all spring from rough country is about 100 difference from the 3/4 ton burb and 1/2 ton k5 if I recall correctly ... So is there any difference between the lift kits and what would you all suggest I go with when the time comes ? Thanks
