chevyridinhigh79
im looking at buying a 77 k10 with a blown 12 bolt and a dana 44 up front. i want to swap in a semi floater 14 bolt and a 3/4 ton dana 44 up front. what would i need for the swap? is it a direct swap or do i need the 14 bolt swap kit? can i use my stock driveshaft with a conversion joint? if so what size conversion joint do i need? and last but notl east can i use my U bolts from the old axles or do i need new ones?
