Im running 3.73s with 40" boggers. It will still sh!t and git if you mash the pedal. Gotta love big blocks.
73-80, 3/4 tons 2 or 4wd, rear will be a full floater. 81 and newer depends on GVWR, but most of the 3/4s I've seen were semi's. All 1 tons are full floaters.
88-up trucks have some wierd things going on. I've seen a couple 1 tons with semi floaters. There are also heavy 1/2 ton, light 3/4 tons, heavy 3/4 tons. Can get confusing sometimes.
As for 15" rims on 8 lugs, depends on what axle and b/s of the rim. I have a set of 15x8s w/4.25" b/s. These would fit on my 97 HD with the pressed on drums no problems. But they wouldn't fit on my 89, which is a 1 ton, but the rear is out of a 3/4 ton, so it has the pull of drums, and it don't fit. I put some washers on it to see if it would clear. 4" would be fine. I also have a set of 15x12" with 3.25" b/s on my 1 ton axles. GM front brakes require grinding to fit, depending on b/s.....
