3/4 ton axles with 3.73 gears, popular?
ugly_blazer
These are all 8 lug - I had always thought that the 4.10 geared 3/4 ton stuff was fairly common and that the 3.73 and 4.56 geared versions were optional, making them more rare. Is this true or am I mis-informed?
The reason I asked is that my friend has a 14FF(open)/10 bolt combo that is 3.73 geared. I said he could use an extra set that I've got, but they are 3.73 also(only difference is that mine is a Gov-lok), is this common?
My 3/4 ton axle also have 3.73 gears. I've got some 4.56 gears for my 14 bolt FF, hopefully I'll be able too find a D60 with 4.56 gears. I'll probley run the 3/4's with the 3.73's till then.
3.73 is almost as common as 4.10, but not quite.
4.56 3/4 tons are out there (I would think) but I've never seen one.
[ QUOTE ]
[/ QUOTE ]I'll probley just run the 3.73's till I find a D60 with 4.56's at a price I can afford. (Buy a wrecked K30 for under $800.00)
The set in my K20 (14FF and D44) are 4.56 from the factory, even the glove box sticker matches.
Thanks eveyone for the replies /forums/images/graemlins/thumb.gif
