3/4 ton rim size?
89k5350
springwater ny
So I swapped a 14 bolt SF into rear of my step side and was curious if I could fit 15 in rims on it so I can reuse my 35s instead of buying new tires for 16s the rear end came out of a 83 k20
The rear should be fine with 15" rims I have a set of 15x10 8 lug I think they were made by Eaton. IIRC front 10B/D44 8 lug should be fine also, D60 front you need to grind some on the calipers to fit.
You will most likely have to grind on the 10b/D44 calipers, depending on BS. I am running the 15" rims over a 14 bff w/ drums and they fit fine. It was the front that needed a bit of grinding.
