Depending on motor, Im assuming a 350, get some with 4.56s if possible. They can be found with a rear locker if your lucky. I would just spend the extra pennies and get front u bolts too. You will be amazed at the brakes too, much bigger and better. You can get away with 4.10s, but Iv always liked 4.56s because if you ever wana get a lower ratio, you dont have to find the carrier too. I think the front driveshaft will be fine, for the rear, you could probably just have one built for 200ish, with the same big joints, and not have to worry about which joint goes where. And 300 aint a bad price if all is well and good with them. The full floater has removable axles, I believe 8 bolts on the outside of the hub, big bolts, like 5/8in or so, the semi floater does not. That being said, I would really look for an axle with 4.56s over the 4.10s, I had 4.10s for a long time with a 350 and a th400, hated it, a dog for sure. Also, easy non dirty way of checking rear end ratio is instead of pulling the cover and counting teeth, you grab the yoke, and turn it over one full rotation and count how many times the tire rotates, if it goes over 3 and 3/4 times, its a 3.73, if it spins 5 and some change, its a 5.13. Its not exactly a fool proof way, but it gets you in the ballpark. the difference between 4.10s and 4.56s is not alot, but it is noticeable if you look closely
