If they are stock axles then the front is a 10 bolt not a Dana 44.
Here are the codes you need to look for I have also seen the tag on the fenderwells before.
GT4 AXLE REAR,3.73 RATIO (DUP WITH 5X1)
GT5 AXLE REAR,4.10 RATIO (DUP WITH GTS)
GT7 AXLE REAR,3.33 RATIO
GT8 AXLE REAR,4.10 RATIO (DUP WITH GT5)
GU2 AXLE REAR,2.73 RATIO
GU4 AXLE REAR,3.08 RATIO
GU5 AXLE REAR,3.23 RATIO
GU6 AXLE REAR,3.42 RATIO
GV2 AXLE REAR,5.83 RATIO
GWL SPRING REAR,9000 LBS CAPACITY
GW6 AXLE REAR,3.27 RATIO
GW9 AXLE REAR,2.93 RATIO (DUP WITH GU3)
GX3 RATIO, TRAN SAXLE FINAL DRIVE 3.33
G44 AXLE REAR,3.07 RATIO
G50 SPRING REAR,HEAVY DUTY, VAR 1
G51 SPRING REAR,HEAVY DUTY, VAR 2
G52 SPRING,RR, 15000 LBS
G60 SPRING REAR,AUXILIARY
G66 LEVEL CONTROL,MAN, AIR
G67 LEVEL CONTROL,AUTO, AIR
G69 LEVEL CONTROL,AUTO, AIR, HD
G80 AXLE POSITRACTION,LIMITED SLIP
G87 AING GEAR,8.50 INCH
G92 AXLE REAR RATIO,PERFORMANCE
G95 AXLE REAR RATIO,ECONOMY
