3" body lift ?
SCRAPPY
Registered Member
BAKERSFIELD,CA
MY BLAZER CAME WITH A 3" BODY LIFT ON IT,BUT THE FRT END WAS DAMAGED.SO I PUT ON A NEW CORE SUPPORT AND NOW THE BODY LINES WON'T MATCH UP. DO I USE THE SPACERS ON THE CORE SUPPORT WITHOUT THE OEM CUSHIONS OR JUST USE THE SPACER BETWEEN THE CORE SUPPORT AND FRAME MOUNT. THANKS FOR THE HELP.....:confused:
frame / factory bushings / body lift block / then the body parts. some positions may come with or require a shim to correct gap diffrence.
and no need for all caps lock as its like you are yelling on the internet.
welcom and have fun safely :waytogo:
A little louder.....i couldn't hear you!!!
