Wanted 30-spline FRT & RR Posi-Units and Axles for 88 K5
trukman1
OH
Looking to replace 28-spline 8.5" open carriers (front and rear) with posi-units and upgrade to 30-spline axles at the same time.
This is for an '88 K5 Blazer with 6-lug wheels.
It's my understanding that 8.6" will work with the right bearings.Please correct me if I'm wrong!
Will consider either size if they will both work.
Thanks for checking this post.
No G80 Gov Locks Please.
I scrapped my housings with the carrier and gears.
I should have one or 2 sets of shafts in 30 spline.
If you find a carrier and need the shafts let me know
I have the front 30 spline inner axles and at least one 30 spline posi. I believe the posi is a Yukon dura-grip. You are correct on running a large hub 10 bolt carrier with a common conversion bearing in a small bearing housing.
GonicGM, Sent a "Start Conversation" message.
