Yep.
), but it still didn't work. This time I confirmed there is no continuity between the relay lugs when activated. So I will be either taking it apart for cleaning or simply replacing it. So the new plugs still don't work yet. Combine that with a flywheel that doesn't work yet, and the truck is still stranded. For now.Yep.
It is puzzling as to why the flywheel rubs,maybe GM had more than one variety that only works on certain years ?...I doubt the crankshaft would be any different for manual VS automatic..
Have you tried pulling in and out on the flywheel (when bolted up) or the harmonic balancer ?...maybe it has a lot of end play in the crankshaft due to a worn thrust bearing surface..the guy who rebuilds starters for me says he sees quite a few vehicles that had damaged starter noses due to excess end play..
Engines that have a lot of end play can sometimes not make any unusual noises and it shows up as thrown V-belts ,or on manual transmissions,pushing in the clutch will bog down or stall the engine..it can ruin front pumps in automatic transmissions too..hope its not that !..
I can feel no end play. Not with the flywheel on, not with the flex plate on, not when it's lonely and plateless. So it's not hitting due to that. And it aligns perfectly with the flex plate.
I think if I could move the starter, I'd be ok. If I could shim out the flywheel, I think its clearance would match that of the flex plate (which would be the correct answer, no?).
So...is flywheel shimming a common thing on these engines? I haven't heard of this issue before now.![]()
..then say "Oh good,its gone" after a few minutes run time..
..and deliver it to the customer without saying boo...
So let's assume I missed the obvious last night, and the starter is the only problem here. What can I do about this? Shimming this starter moves it vertically, I don't see any way to move it further forward. I could try shimming the flywheel, as Rob suggested, but I'm not sure how this is done, nor how much shim I would want. It clearly works with the flex plate, but not with the flywheel. I find that odd.
Thoughts?![]()
Not sure if that's the best way to do it but its a start. Are you sure that the flywheel is for a 6.2?Those newer rims 17 "..?...I've been told by local salvage yards 8 lug 17" steelies from 2007 vintage trucks will work on square bodies without rubbing,etc..
All 4 of the tires I took off my pickup were plugged at least once--one had 3 plugs in it,one right on the shoulder of the tread too,but never lost any air..
I've never had to take a flex plate or flywheel off a 6.2,some engines do have one shim behind the flywheel factory,but I dont know if GM put one on the 6.2's or not..
I would say if it rubs the starter only,and just in one spot not critical to the drive end bushing,that simply filing or grinding a tad off it wouldn't harm it...
Most "mechanics" here would probably just install everything and fire it up,THEN say "hey,whats that grinding noise"?....then say "Oh good,its gone" after a few minutes run time..
Have you figured this out yet!??? It`s driving me nuts!![]()
I would measure the distance of the ring gear to block with the flex plate and the flywheel, make a shim out of the flex plate if you have too. A machine shop should be able to make that easy.Not sure if that's the best way to do it but its a start. Are you sure that the flywheel is for a 6.2?
But it's gotta be out there...
When I went to the ARP parts bin for my flexplate hardware, they had lots of options. Also, I'm pretty sure you can get a full shim for between the crank and flywheel....I'm more likely to grab some washers and adjust the depth until it's happy.
But either way I think I will need longer bolts. With superly-low-profile heads. Not sure where to find such without taking a normal bolt head to a bench grinder.
David
Of course I did!Did you end up using that clutch behind the 454 Dean?
