Care to share an eta?
It was 4* here yesterday. Forgot to plug my 6.5 in, but it didn't care. Fired right up.
D. All of the Above
What's with the front axle swap? Not going to just swap the outers?
Sounds like a nightmare.
Martin
Martin
I agree. I think if you did that cables would be the way to go.
Every linkage joint is another opportunity for binding or misalignment. Cables would be less of a nightmare.
I like it. You wouldn't even need to do any fabbing in the cab. Just secure the cable housing to the firewall, and use the stock mechanical shifter mechanism that normally moves the shaft to engage the auto trans...
If you did it clean it would be pretty trick imo.
That would be a really long cable though.
I've got a center console design using the power of ratios to put my shifters in a better spot and shorten the throw.
I would also like to move mine, because I want to make a desert style center console that would go all the way up to the dash. But then I cant shift the tcase... But I would like one on the console I will build.
I will agree with Adam it would be pretty trick if you pulled it off
Lokar has a cool column cable shifter for our trucks. I had one in mine that worked good.
And nice find on the axle! That's a win all the way around.
