buffblazer
any difference between a 69-79 chevy 350 and an 86 350? can 86 parts be bolted to the 69-79 block? any problems i may have switching over everthing.
One piece rear main motors take a different flywheel. Trans and accessories will bolt up otherwise.
Wish you were closer, I'd trade you flywheels.![]()
)they're clamping so tight they push the cam forward?..i knew they gripped, but never wouldv'e thought the pressure plate would push so hard that it mess w/cam...would a button stop this?
ooooo...wears the thrust bearing then,huh. so the centerforce pressure plate can cause premature engine slop/death?
