Idle was at 1000 so lowered it to 750-800 ish now.Doesn’t sound too bad. How much did the idle RPM change? Where’s your vacuum gage?
So all the chicks down there look like that?Yeah Phoenix is flat
Anybody want to join me while I push this f-ing thing off a cliff
He built them at his house... so, unfortunately I think that's not as optionGo to the shop An option?
Nope... only yesterday but just after I got oil all over everything checking rockers while running. I bet some got in the exhaust flange areaAny smoke from the exhaust?
Wishful thinking but maybe they'd order 2 and I'd get dinner hahahaWhy? They would just regurgitate it……..
This is what I was afraid of but knew would most likely be the issue. I've seen countless videos and threads in regards to those. A few videos again Kerri or myvintageiron7512 said he will no longer make or use flat tappets in anything going forward...I'm predicting a bad lifter, or lifters. It's epidemic, and it has nothing to do with the skill of the engine builder, or how exact the cam break in was done. These flat tappet lifters out today are like playing Russian Roulette 16 times in a row. The occasional ones are not hardened properly (or at all), but most common is they are machined dead flat on the bottom, instead of slightly crowned. When they're dead flat, they do not spin...and then they fail. First it's a small tick, so you re-adjust the valves thinking you must have messed up a little. It's quiet again, but then the tick comes back...because the lifter is destroying itself.
