Pizza_Man
Okay so here's the truck
71 Jimmy 350/465/205 14 rear with 3.73 gears and 36" tires
Motor has MSD ignition, hooker headers, edelbrock air gap intake, edelbrock 750 carb 1411, mild cam, K&N air filter, it is the 71 motor and hasn't been rebuilt and has about 150k on it.
For some reason it doesn't want to accelerate past like 50 mph. No matter what gear. In 3rd it starts cutting out around 3k and sounds like not all 8 are firing. And in fourth its the same story but at 2k rpm. In second, first, and low revs in third it runs fine and accelerates as normal. But then it hits 3k like a wall and just won't do any more. In neutral it normally could hit 6k and climb but not it wont get past 5k. And i havent really been too hard on it lately. Spark plugs are 3 months old and it was running just fine before this. I changed the in line fuel filter and checked the spark timing.
Is there a filter inside the carb?
Thanks everyone so much!
