Lunatic
This will be the second time in 4 years that this has happened. The first time I "knew" it was the timing chain (but wasn't) and installed a direct drive gear set. Re-timed and has been running fine since.
Just the other day, I was driving through a neighborhood, almost idling. I turned onto a street, gave a bit of gas. and the engine stuttered - And just like that, it is now running like poo.
I can testify that everything is operating smoothly (bearings, push rods, etc) by using an automotive stethoscope all over the top and bottom of the engine. I just cant reason "how" the timing jumped, nor can I find where it jumped to. All I can achieve at this point is a very rough idle and a QJ that backfires under heavy pedal with no load.
A bit of info for the engine: 350 with stock internals, SMI QJ, Edelbrock 3701 intake, Accel Correction 8141R dizzy cap, new AC Delco plain jane spark plugs, Proform noisey direct drive, vacuum lines less than a year old.
I can only come with 2 ideas, both ignition related. Either my timing mysteriously jumped somehow, or my stock dizzy went south.
So before I tear down my engine, I thought I'd come through and present the case to the brotherhood. Hopefully, someone can point out something I haven't thought of or considered looking at.
I hate asking for help, but here I am. Ask any questions and I'll respond quickly. Comments and suggestions are appreciated also.
Troy B
Ft Hood, TX
Troy B
Ft Hood, TX
