87sub91
Newbie
Hi there, I am new to CK5 and I am hoping you guys can help me out with my 1991 4x4 Suburban. The problem that I seem to be having is the truck misfires at idle only. You can hear it in the exhaust and feel the engine shake only when it is idling, put it in drive and it goes away. Drives great with good power and gets decent gas mileage. The truck has the stock L05 350 TBI with 192,*** miles. I have replaced just about everything once or twice. The things I have done to the truck are (new intake gaskets, plugs, wires, dist. cap+rotor, distributor, TBI rebuild, CTS sensor, knock sensor, and map sensor.) I've replaced all the vacuum lines, thinking that the miss was caused by a vac leak, no fix. I have yet to find a vac leak anywhere. I'm just about fed up with this thing.
Any help will be gladly appreciated, Thanks! Oakley
