bp71k5
3/4 ton status
I've done both and now the base timing is at 0.
She's idling now with the EST reconnected and seems ok.
I put the timing light back on the markers but the mark on the balancer does not line up anywhere on the timing cover
Is that the whole point; set the base timing and then the ECM takes over?
Yep, that's the point. The timing mark is probably running around 20 degrees advanced at idle if the ECM is controlling it.
