bigblaze76
Registered Member
so i was told my transmission was rebuilt so when i finally got it installed i was reminded to never trust anyone...
the first problem was it would hesitate to shift from park to reverse when i fist started it up...so i was told that might be the front pump...bummer
when i did drive it would not shift from second to third and i could manually shift it so i read up on it and found out is was probably the governor gear. I pulled the cover off and found that the valves were not working cleaned it up and got the valves working put it in and shifted perfect for the first 5 miles then it happened again this time i could not manually shift so i pulled the governor gear out again this time the teeth are chewed up.
so my questions are, what causes the gear to get chewed up like that and if i put a new one in will it happen again?
and the last question should i drop the pan and try to get all the plastic teeth out?
thanks for all the help in adavnce
