a noid light would do you wonders right now...
A noid light isn't needed if he already knows that the injectors are firing (he can see the spray pattern).
I have no idea what that is![]()
A noid light is something that you plug into the connector for the injector and it tells you if there is a signal at the injector wiring by lighting a light.
well, it's obviously not spraying, or receiving signal to spray if it's not running with the one connected.....
I bought the set...Ok guys here's what I just discovered. I had some help from a coworker. I cranked the truck with either injector. But it only ran for limited time with the driver side alone. When i cranked with the passenger side it kept running and would rev higher. Looking at the streams closely it appears that the passenger side is dumping more fuel which causes the higher idle and I assume the rich flag.
Bingo, EXACTLY what my very first reply said, a clogged injector causing it to spray too much fuel.![]()
So the issue would be that the passenger side is clogged?
The internals of the injector could have a piece of crap holding the pintle from closing fully which will allow a continuous fuel supply, or there could be something stuck in the injector pod where the injector sits into. Regardless, if you have another TBI unit and it has the same size injectors I would swap the one in question with a different one from your back-up TBI.
So the issue would be that the driver side is clogged?
