no I didnt I'm not sure where to look. I think it's the first two holes. Yea I need to change the oil then. I've been thinking about running a mechanical fuel pump instead.Pouring gas into the carb can only work for a few tries. Remember, all that gas is running past your rings into your oil. Like Scibbles said, starter fluid! Did you look into the carb to see if gas was being injected into the engine? Beauty of a carb is you can see it squirting inside the carb.
