35's, no lift, lots of fender trimming?
sandy78
Utah
Can I do it? I mounted one on the front and it doesn't seem to hit anywhere, but I cant really flex it out with my floor jack......Has anyone else done this? I have had no rubbing at all with 33's, but 35's are bigger:grin:
Better get the saw out now. I test fitted my 35's and there was no room to do anything without lift/cutting
i have kinda i only have 1exta leaf up front mybe 1.5in lft i cut to the inner fender flush
i run 35's with my K20 stock susp.It s not rubbing when u look at it but when u drive and sharp steer(specially goin downhill then up)it will rub and rub good too.
I bent my f. fenders first:frown1: ...and then i trimmed the fender corners
with the:weld: torches. now it's wayyyyyy better but still rubs sometimes(just a bit):D
2"body lift, 36" tall TSL's, and no trimming. They would clear without the body lift i bet. They dont rub on road or off. Its all in rim selection and tire width.
I'm running 33x12.5" tires with stock springs except for 1-ton 3 leaf springs in front which puts the truck about level and half-ton springs in the back. No rubbing to speak of yet, running them on 15x8" wheels with 3.75" BSing
On my 85 K5 I've got 33x12.50's on 15x10 rims. For now the suspension is still stock. Everything clears fine until I go to make a turn. The fender lip will catch the edge of the tires. It didn't happen on the 15x8's but the 15x10's are for sure rubbing.
if you run narower tires 13.5 wide and under with stock backspacing rims you can do it with no problem. i run 39.5x13.5x16in iroks with only a 2.5in lift
Or.....35's with minimal cutting and NO WHEELING!!!
Here's a pic of a truck I used to own (88K5, no lift, 35's):
I did a slight "cut" on the trailing edge of the front fenders to allow the front tires to turn....and I think I had to nip a slight bit from the leading edge too.
Strictly a "street" vehicle. I had no illusions about that setup working offroad.... I think it would have rubbed even at the mall. :D
One way suggested to me to check flex/interference is to put one rear tire up in the air (such as on a ramp) and do the same with the opposite side front.
That looks like the same trim I had to do to my truck
I run 35X14's on 15"rims with 3 or 3 1/2" bs.
I also had to beat the front of the fenders in to reduce the rub while turning and flexing
Now there is only minimal rub when it starts bouncing off road
There seems to be a big difference from truck to truck as to what will fit ,what your buddy runs won't work on another:dunno:
what about running 315 75r 16's with a 2 inch body lift?
