39.5x15-15 TSLs in MI/WI
CyberSniper
Chelsea, MI
These were sold a long time ago.
$750 or best or trade for some Ford/Chevy or maybe YJ parts. The price goes down fast if you've got something I want.
I live in the western Upper Peninsula of Michigan but will be making the trek down to mid-Michigan (Flint/Lansing area) at Thanksgiving.
The baldest one is 19/32nds. The two with the most tread have 21/32nds. They're all marked with the location I ran them. They're all measured between the center lugs. The one in the picture where I measured it is right where my thumb is.
My pastey-white hand trying to show the bald tire's tread depth:
Smooth bottom Dana 70 (Dana 70U) with the proper pinion offset (.625") and 35 spline shafts. Basically, I need the BOM so I can look it up on Spicer's site. And a real locker for it.
4.10 geared Detroit/Open 14FF... or with 5.13s... or with disc brakes (goal is either a detroit or welded 14FF with 5.13s and disc brakes).
SYE for a 241, preferably a super short
Married Ford 205
Full case locker for a 35 spline 60
1350 or 1410 U-bolt yoke for a 60
10,500lb or heavier hydraulic winch... needs to be power in/out
LS1 (haha)
44s (not axles)... or bigger
16.5x10 or wider 8 lug steel wheels... or beadlocks with ~4" of backspacing
GM 3/4 ton or 1 ton 56" rear springs in really good shape or 4" lift ones
31x10.50r15 all terrains
33x12.50r15 all terrains
15x8 4" BS chevy 6 on 5.5" aluminum wheels
Full manual doors for a 80-91 chevy fullsize
4.3L V6 roller motor, complete
i got some what else would you need very little rust and they are white
