I would like to get advise from you guys since we all have similar rigs in here. Before I found this forum, I got a lot of great advise from a couple other forums by guys that are in the muscle car scene and they had a lot of knowledge on the engine component discussions but I felt like I needed the expertise from truck guys when it came to the gearing, so I appreciate any insight you guys have to offer. My 85 K10 SCLB has a 350sbc, TH350 with a 6" lift and 35" tires.
Motor: it started life as a very humble GM crate and I'm doing a Vortec head swap (modified to accept .525 lift), Eddy performer RPM intake (1500-6500rpm), Eddy performer 750cfm vacuum secondary carb, and Lunati Voodoo cam (1400-5800rpm). Cam specs are .468/.489 lift, .219/.227 duration @.050
Rear axle: Swapping out the 10 bolt with a junk yard 14 bolt FF that is being completely rebuilt from WMS to WMS. I'll be keeping the front 10 bolt for now and just doing an 8 lug conversion with a regear once I choose the gear and this is where I'm stuck. What I DO know is it will be either 4.10 or 4.56
The car guys for the most part say it will be soggy on the bottom end with anything under 4.56 since I'm not going the RV/towing cam route. The truck is primarily a toy and will be a back roads/trash truck/toy kind of rig, so I wanted to go a little more aggressive with the cam than a low lift smooth idle cam which there's nothing wrong with that, I just wanted to have a little more under the hood. I moved my RPM range up a little with that cam but I figured I could compensate with gearing. I'm not concerned with MPG or even highway RPMs BUT I don't want to be completely wound out at 60 mph at the same time.
So there lies my question. I'm leaning toward 4.56's and have been for a while and from talking to friends and researching, it seems truck guys aren't as convinced that a taller gear than 4.56s would make the truck (with my motor specs) a terd on the bottom end. Maybe it's because car guys by default have launching from the line at the drag strip programmed in their minds, I don't know.
The 14 bolt had a 3.73 geared Gov Lock so I have to buy gears AND a carrier because I want to run a Detroit locker and the Gov Lock carrier will not accept a locker. A G2 carrier compatible with a locking diff is $400ish and this creates an issue because of the 14b FF carrier break between 4.10 and 4.56 gearing. From my understanding, if you have to pick, it's more desirable to use standard gears instead of the thick ring gear. If I go 4.56 (with a 4.56 and up carrier to keep a standard thickness ring gear) and later decide I want to go back to 4.10, I would have to buy another carrier along with the 4.10 gears which will just be more cash I don't have. I know I could get a 4.10 and down carrier to begin with that will work with a thick 4.56 ring gear but I just would rather not use a thick ring gear. BUT (lol, I know.. It's my friggin OCD kicking in) if I got a 4.10 and down carrier with the thick 4.56 ring gear, I could keep the carrier and then just go shop for a standard 4.10 ring gear and pinion if I were want to take the 4.56 out and go with 4.10s.
The whole standard vs thick ring gear thing is just a secondary thought but my preference is to not even change gears once it's all built. I want the gear that will work best with my motor specs to give me a good pulling/accelerating bottom end. Eventually, I'm rebuilding the TH350 tranny and can put a higher stall converter in if needed although I don't know that it will be necessary. The RPM power band isn't that high I don't think.
Sorry for writing a novel on this but it's a lot of cash and labor to me and I'd like to avoid round 2. So anyway, 4.10 vs 4.56.... what do you guys think?
oh well.
