I have used a cam practically exactly like that in a similar engine, heads were 882 so less power overall. Truck was a 72 k20 had 31 inch tires and 410 gears so pretty deep, same carb same intake etc. pretty close besides the tires you are running, I had to bump stall to 2200 and I felt that wasn't enough IMHO.. and it made really decent power for a practically stock sbc 234whp and 289 tq at the wheels.
If it was me I would go 456 because that cam makes good torque but not right off idle like an rv cam but it was much better all around than an rv cam motor. it makes power all the way to redline. makes a good sound, mpg wasn't that good but 2800 at 70 isn't great either.. I towed a lot with that truck and never felt that I was underpowered. Also the main reason I cammed up to that is because on the freeway my rpm was higher that 2500 anyway so why choose a cam that is loosing tq and not one that is making it and has more left??
I also chose it because when your truck has to shift into 2nd on a hill (heavy load) it would pull because it has some breath left.. rv cams tap out way sooner than this did. it pulled 4krpm all day no problem..
https://www.youtube.com/watch?v=2uA8VOdHZ2A
