4.11 gears and 4.10 question
really ....thanks...i was told that because of the the same teeth meshing so much would cause it to wear the set out earlier...well thats good to know....i was told the 41 tooth ring and 10 tooth pinion was beefier than other ratios ....is this true?
for what diff are we talking about here? and no It wouldn't be any different strength than say a 3.73. if you get into the really low gears like 7.17s for the D60s its said strength decreases.......but a friend ran 7.17s for a few years locked with a 434SBC at 500hp with no problems. So who knows.
