Dillyp
Registered Member
So after getting to wheel a little for the first time since the sniper efi and 35's, I was left unsatisfied with the factory 4.10's that my blazer is geared. My last blazer had 4.10's and 35's, but driven by an sm465/np208. My current rig has a th350/np203. Im not looking to run a doubler, change trans or transfer case. The 4.10's were close to perfect on 33's, but just a little too lackluster with the 35's. The blazer gets a 50/50 mix of cruising/daily driving, and appalachian trail crawling. What would you recommend, 4.56's or 4.88's?
FYI they are stock 8.5 10 bolts with no intentions of swapping danas or 14 bolts. The gov-lok will be scrapped and a lunchbox will go in the rear, possibly the front while I'm at it.
