The box seems to be reacting fine. I can turn the wheels just by turning the rag joint by hand.ryoken said:is the box reacting immediately? maybe get the mrs's out there to turn the wheel while you watch down below..
i remember you researching your geometry on here and thought you had a good handle on that, drag link angle, etc.
keep us posted, i'd like to hear what you find...
As to geometry, I knew the stock system fine, and as far as i know I understand crossover. The caster needs to be checked for sure but I'm clutching at straws hoping it's that.
I've never driven with crossover before, maybe I'm expecting too much from it? If I can get it to drive almost as good as stock, then I'll go back to stock as this is scary as it is!
