Hey guys I just finished up a 4" lift on my 89 K5. Tuff Country EZ rides in front with a DIY4x Shackle flip in the rear with 4.5'' shackles. I have a vibration from around 20-60mph under throttle and off throttle. Above 60 it is minimal.
I have measured my angles and have 2* at T-case output and 14* at pinion. Overall driveshaft angle is 17*. The K5 has a 700R4/241 with a 10 bolt rear end and a stock single joint rear shaft. I have spoken with Kert and we both think 14* pinion angle is high.
Has anyone else run into this problem with the shackle flip or am I the only one? Since there is no way I can shim my diff enough to cancel vibes, what is my next best option? I do not have the resources to move perches and shock mounts. I'm guessing CV shaft.... I was hoping I wouldn't have to worry about vibration issues since I only went with a 4''. Thanks for any input!
